Changing Ae82 4age Drive Shaft
Hey I'm just gonna change my AE82 4AGE passenger side drive shaft. Is there anything i need to know that can make this job easier to get the shaft out of the disc hub? I know theres 6 nuts on the gearbox side and then the wheel nut with split pin. Anything that you can tell me that will make this job eaiser will be much appreciated. THANKS!
get yourself a can of penetrant, and a soft faced hammer, as sometimes the shaft can be rusted in the hub end where it splines with the shaft. You might need to give it a good smack.
DO NOT hit the end with a normal hammer, as you'll flare the end of the shaft
also make sure wen u put the shaft back in u put a lil bit of grease on the splines..n jus make sure it goes the whole way in...double check if u hav 2...but make sure its right or ull wreck the shaft and the inner spline in the gbox
