Everything posted by Rollaboy2608
Questions? Battery Relocation Help
too right, in fact, unless its absolutely necessary, i wouldnt shift my battery to the boot, as you're only increasing the chance of getting a bad earth or a major voltage drop
Spark Problem
even simpler, check your plugs, as they are critical, and often left unchecked. Also, often they can look fine, but are actually fcuked
Cleaning My 4k Engine
Winke, porting and polishing has nothing to do with a clean engine bay. You have to think before you post dude!!!!!!!!! Give the bay a good degrease, thats a good lace to start, making sure you cover electronic or electric components. Then, if your really anal, start pulling things off one at a time, then paint polish or hit them with brake cleaner. This should give you the desired finish It really depends on whether you're after show engine bay, or clean factory bay
Rwd 4age Kits Available
if you were really energetic, you could make a hall effect pickup for the crank pulley, and adapt a sensor to it..... Probably easier to go the dizzy route though
- Block Material.
K50 Gearbox Oil
Redline is tha shit, having said that, it isa K50, is it really worth it???
7k Into Ke70
Thought I'd drop my two cents worth in.... The 7K flywheel and clutch will not fit in a K bell housing, trust me I tried every avenue and it just wont happen, unless you remove metal from the inside of the box, and after that you wont have any adjustment, because the throw out bearing rests on the pressure plate. You must use the 4k clutch/flywheel Also, I don't know if this will be the same for KE70 as it was for my 30, but the heater outlet pipes are smaller on the car than on the engine, and mine is carb'd, so there is f@$k all room for fitting up heater lines, which might not matter to some, but it is annoying. Put it this way, its not a bolt in like some would have you believe, and 7K engines are easily obtained, but shop around, as I paid way too much for mine, in hindsight.
4k Valve Springs??
geez talk about multiple topic posting!!!
Ke55 Corolla Stalls Whenever It Slows Down
check needle and seat, easy to do, costs a few bucks, also check for vacuum leaks
Any Easter Cruisers
where would you like to go? I'm going test driving new cars on saturday in Blacktown, will probably be in the Rolla
Rust Repair Panels For Ke55 Hardtop
where did you get them from? I'd be after a pair, otherwise they wont match
thats actually a good one Winke, I hadnt seen that on RSP before. I've looked around, and havent been able to find any rust repair panels for KE30's at all, or new panels for that matter. A pair of chinese new guards came up once on Ebay, but i missed out on them, and havent seen them since
Ke35 Question
Winke, you obviously havent seen how much a clean KE with a 4AGE engine will go for these days. And you really shouldnt say that you don't know anything, because if you don't, you probably shouldnt be commenting :sob:
Ke35 Question
Its pointless to add the sum of what a front cut would/might cost, with the estimated value of a standard KE35. There are many more points to consider, such as: How professionally carried out was the conversion? How well does it drive? rattles,squeaks,vibrations, all these things are things that I try to pick up on, especially when conversions have been done. Has it had a respray?Does it have rust? Dents? bog ripple? Interior? rips, stains, original, reupholstered? Service life? Stereo? All these things add to the evaluation for me. I would never add the price of a motor to the "normal" price of a car and make an estimation based solely on that assumption An item is only ever worth what someone is WILLING to pay for it. e.g XY GTHO Falcon $750k WTF???????
Low Springs?
look, I'm sorry, I didnt mean to knock you personally, it just seems like alot of the members of this forum, seem to be too lazy to do their own "legwork" and find out things for themselves. When I go to buy anything, I always enquire with every provider of that product/service I can find, because sometimes the difference in price can be astronomical. The more you shop around, the more you learn, and thats not directed solely at you, it should be for all members who don't realise this simple fact.
Ke35 Question
looks pretty tidy to me, I would say $6000 grand no worries, as long as paint/interior/running gear all good quality?
Low Springs?
ring a suspension shop. If AE70 knew the price, his forum identity would probably be "AE70 suspension". But its not, so use the phone, or speak with GSL. Try a member search!!!!
Changing Ae82 4age Drive Shaft
good call, always helps with ease of reinstallation
get yourself a can of penetrant, and a soft faced hammer, as sometimes the shaft can be rusted in the hub end where it splines with the shaft. You might need to give it a good smack. DO NOT hit the end with a normal hammer, as you'll flare the end of the shaft
Super Charging
full stops how dare you taz!
The Term "mint"
hmmmmm..... "hey bro, my car is fully Mojito, yeah?"
Corey Delaney
can someone close this for the love of god
Sand Blasting Calipers
never sand blast calipers. if you get the fluid galleries full of sand you'll struggle to get it all out, and it will cause leaks. use a soft wire wheel
The Term "mint"
Hey Gavclaasic, I believe it was you who gave me the idea for this thread actually. I also agree with your definition of the word overrated. It may be that times have changed with which words we use, but myself personally, I feel we are americanised enough, without having to resort to gangsta talk to recognise a nice car from an original factory classic
The Term "mint"
yeah thats the way I see it, but the term gets bandied around alot for just about anything...
