never
  1. Good call on that one. Found a place near me that sells felxible hose that you apparently bend to the shape. Never knew it existed. Always learning something on here.
  2. Went to repco and tried pretty much everything in store... no luck.
  3. Hey, Bottom hose on radiator got too close to the alternator and was cut. Need a new one now but don't know what hose to get. 2tg engine with a standard ke30 radiator. I have the hose that was on there but have no idea what it came out of. Hopefully someone can help me. Got pics below of where the hose needs to go and what was on there before.
  4. what he means is that it's too big and therefore will go like shot. Do a search of the FAQ or forum for suitable carbs
  5. Beat me to it. Heard about this at work. Have you posted this up at toymods? Pity my car has had too much done to it cause otherwise it is certainly clean enough.
  6. search for a hydraulic clutch post by kangaroosa. Did mine like that and worked perfect
  7. mostly grandma style driving but occasionaly the intake noise gets the better of me and its gets a fair amount of 'right clog' as you put it.
  8. hey guys, Hoping for a bit of help here. I recently put a 2tg into my rolla and of course expected the fuel economy to be worse than the 5k that was in there. Not this much worse though. Getting 16.5l per 100km under fairly normal driving conditions. Engine has mild cams and head work as far as I know and is running twin weber 40s with 32mm chokes. It was running rich and had machined out 34mm chokes and jets to suit then I got it rejetted with the 32mm chokes but it hasn't made a significant difference. So all you 2tg owners what sort of economy are you getting? And what carbs are you running?
  9. You are a smart ass :) Its more a case of me just not wanting to get cold and wet... plus I am assuming there wont be as much of a turn out if weather is bad anyway???
  10. I will be there in 2tg ke30 provided the weather improves. Not looking good so far.
  11. I liken that car to cross dressing, I don't understand why you would do it but if it makes you feel good who am I to judge.
  12. Just make sure his fully hektik commodore is parked well away at all stops and for photos :lolcry:
  13. 1) Soyboy 2) Bowler 3) BKS. 4) OSODVS 5) 78_7kRolla 6) The overrated KE70 7) Never
  14. I and many others will point you in the direction of the faq and the search button... But because I am a nice bloke. The 32/32 in my opinion is perfect. Had one on my 5k and it delivered more power and better fuel economy than the standard aisin. See what the jets are in it cause more than likely they will be okay. Very good idea to get it checked over for condition though if you can't do it yourself. A carby will always run crap if its worn.
  15. Try meridian motorsport in moorabbin. Guy there named toby has done a lot of work on the 4a in mr2s and in corollas. He is always very happy to have a chat with you. Wouldn't say he is the cheapest mind you but they get a lot of race cars going in and out of the place.
