March 25, 200818 yr comment_235130 I'm doing a 4AGE conversion and i no i need to change the clutch. i have everything i need I'm just not sure where the master cylinder goes. i no u have to drill holes in the fire wall for it to go in but again I'm unsure of where. any help would be great cheers Report
March 25, 200818 yr comment_235132 its pretty much trial and error. Install your ae71 pedal box, and youll get some sort of an idea where to drill. You can try drill from the inside but i doubt the drill will fit. i installed the pedal box and got a punch and punched a little dent from the inside and then looked in the engine bay and where the dent was i drilled. then you just extend the holes a little bit till it all fits sweet Report
March 25, 200818 yr Author comment_235161 cheers. does it go through the same hole that the cable clutch line went through? Report
March 25, 200818 yr comment_235162 You can try drill from the inside but i doubt the drill will fit. incorectomondo this is the way i would recomend to do as i did this in mine if u don't do it this way u will end up with drill holes all throught ur firewall Report
March 25, 200818 yr comment_235164 cheers. does it go through the same hole that the cable clutch line went through? no it doesnt also should mention that u will have to angle grind the cable clutch hole a little as the master cylinder fouls on it Report
March 25, 200818 yr Author comment_235176 no it doesnt also should mention that u will have to angle grind the cable clutch hole a little as the master cylinder fouls on it i figured id have to do that. just wasnt 100% cheers Report
March 26, 200818 yr Author comment_235326 I'm still having trouble. are the ae86 and ae71 clutch pedal boxes the same? i have an 86 one and after having a look, it looks like the ke70 pedals are all one unit. can anyone shed some light??? Edited March 26, 200818 yr by h1_roll4 Report
April 2, 200818 yr comment_236799 A Trick I used - Take your pedal box and a piece of cardboard. Create a template using the card marking bolt holes and the master holes. Install the pedal box and then line up the card on the engine bay side, and viola your know where to drill. Report
