April 26, 200818 yr comment_242099 ok guys so i have a ke70 with 4age rwd conversion. anyway last night was driving like abit of a ***with tryed to smash it in second wouldnt go in, then i couldnt get it in any gear. but if i turned the car off i can get it in all gears so thats how i drove it home turned it off put it in first n drove it home luckly i was close to home. checked the fluid this morning there was nothing in it so i topped it up but still have the same problem. i put a camera underneath the car so i could see what was going on when pushing the clutch in it looked like it was working so i don't know what the hell is going on.. any help would be appreciated thanks Report
April 26, 200818 yr Author comment_242111 so i figured out what is happening.. when i push the clutch 3qtrs of the way everything is fine i can get in gear allof that but wheni push the clutch in all the way it engages abit :yes: why would it all of a sudden be doing that and how could i solve this thanks Report
April 26, 200818 yr comment_242138 You said it was empty? the reservoir? and you topped it up? Saying that, it was bone dry, obviously its leaking from somewhere. Have you inspected the clutch master cylinder? Slave cylinder? And clutch hoses and lines? When you filled it back up again, did you bleed the clutch system? Sorry for all the questions but it needs to be narrowed down, cheers phatke30! Edited April 26, 200818 yr by phatke30 Report
April 26, 200818 yr Author comment_242180 You said it was empty? the reservoir? and you topped it up? Saying that, it was bone dry, obviously its leaking from somewhere. Have you inspected the clutch master cylinder? Slave cylinder? And clutch hoses and lines? When you filled it back up again, did you bleed the clutch system? Sorry for all the questions but it needs to be narrowed down, cheers phatke30! hey mate thanks for your reply. um yeh it was completely empty. yeh i had a look at the lines only thing that looked dodgy was the um I'm not sure what its called its the thing that pushes the leaver coming out of the box looks like there had been fluid leaking from around the boot. thanks for your help its appreciated Report
April 26, 200818 yr comment_242274 No drama's, sounds like you may have to replace your clutch slave cylinder of recondition it fella, cheers phatke30! Report
April 26, 200818 yr comment_242276 Not a big drama at all. Just remember to bleed it properly after you put the new slave cyl in :lolcry: Report
