May 4, 200818 yr comment_243874 I recently acquired a 1980 Te-72 sedan. I was wondering what wheel offset/ lug pattern i can use. Also i have a set of 1984 240Z wheels will these work for me? Report
May 5, 200818 yr comment_244278 yes they should be okay, they arnt the best offset, they will sit inside the guards a little but a nice upgrade from standard. stud pattern is 4x114.3 popular sizes are 14x7 zero-low positive offset wider wheels need more positive offset to sit the same. also if the car is really slamming low then you may have issues with guard/tyre clearance. if you get wheels that are too positive they will hit the strut. for example, I'm selling some 14x7 -5offset and on my lowish car i had to flare my guards slightly but with a higher car you could probaly get away with standard guards, they also where fine on the front with super stiff springs because the suspension didnt dosent move to the finger thickness clearance on the guard/tyre is fine. Report
May 5, 200818 yr Author comment_244305 Thanks for the help i really appreciate it. :POSTPICS!: Report
May 7, 200818 yr comment_244782 no problem, feel free to post up the specs of wheels here if you like so that someone can confirm they they will fit.. like the right offset etc.. Report
