May 10, 200818 yr Author comment_245434 Like would i need to upgrade anything, put anything else in for it, or just the t50 just go straight in? Report
May 10, 200818 yr comment_245440 Assuming this is behind a K motor? Convert it from cable to hydraulic clutch (Need bits from an AE71) and you will also need the K-T bellhousing (Pretty rare to find). Report
May 11, 200818 yr Author comment_245670 Assuming this is behind a K motor? Convert it from cable to hydraulic clutch (Need bits from an AE71) and you will also need the K-T bellhousing (Pretty rare to find). Nah mate I'm getting it when i buy my 4AGE sorry, should of explained more :D After my 4AGE is in ill put the gearbox in, Does it still need parts from the ae71? Edited May 11, 200818 yr by interlopr Report
May 11, 200818 yr comment_245677 You will need a donar AE71 for the Hydraulic clutch and pedal box setup, Gearbox Crossmember etc etc etc.. Report
May 11, 200818 yr Author comment_245684 You will need a donar AE71 for the Hydraulic clutch and pedal box setup, Gearbox Crossmember etc etc etc.. Ok cool as, thx mate! Report
May 11, 200818 yr Author comment_245701 Ok well instead of the t50, what about a k50 5spd box? do they slide straight in? Report
May 11, 200818 yr Author comment_245709 K50 will not bolt up to a 4AGE.. I mean onto the stock 4k lol, need a 5 spd to get me to n from work since i use a highway, 4 spd doesn't pull it :D Report
May 11, 200818 yr comment_245713 What is it, First you say 4AGE, Now you are saying 4K? In a KE70 For a 4AGE you need to run a T50 gearbox In a KE70 for a 4KC you need to run a K50 gearbox is your car auto at the moment or manual? if its a 4 speed manual just put a K50 in it and be done with it.. Report
May 11, 200818 yr Author comment_245714 What is it, First you say 4AGE, Now you are saying 4K? In a KE70 For a 4AGE you need to run a T50 gearbox In a KE70 for a 4KC you need to run a K50 gearbox is your car auto at the moment or manual? if its a 4 speed manual just put a K50 in it and be done with it.. ok thank you :D totally newb at this, lol, Yeah its a standard KE70 4spd 4k. Want to make it 5sp, so just purchase a tasty K50 and whack her straight in? Report
May 11, 200818 yr comment_245719 yep, just make sure its from a KE70 as there are 2 different types of K50 (Different extension housings = different shifter positions).. Report
May 11, 200818 yr Author comment_245722 yep, just make sure its from a KE70 as there are 2 different types of K50 (Different extension housings = different shifter positions).. It's out of a KE70 Wagon? Would that still work? Report
May 11, 200818 yr comment_245724 That will work fine. Just got to watch out for the earlier model Corolla 5 speed boxes.. Report
