June 20, 200818 yr comment_254591 having problems with clutch cable atm. can't seem to find how it goes, i got some pics so maybe someone can help. Number 1 seems the obvious spot for the clutch cable to go thru, but that means it has to bend sharply to reach top of pedal (number 3) Number 2 seems right for it, but the rubber cup bit the cable go through don't fit in in thaat hole. I'm lost. very lost Report
June 20, 200818 yr comment_254599 #1 is the hole Nick cut for a hydraulic clutch. #2 is were the rubber boot on the cable sits #3 is were the pedel end of the cable attaches, and will line up with #2. :lolcry: Report
