I JUST GOT MY NEW EXHAUST DONE AND JUST STARTED RAINING.
SO DECIDED TO GO OUT AND MY DIFF DECIDED TO BLOW.
ANYONE NO WHERE YOU CAN GET GOOD LSD DIFFS FOR CHEAP ?
FOR KE70
THANKS
First step would be to use the caps lock button, now I'm yelling in my head....
What diff... Stock there is no lsd options.
btw lsd diffs translates into = limited slip differential differential
Has it been upgraded from OEM? If not that you don't have any options. And your going to have either buy another one and lock it, not lsd. Or get an entire new diff casing.
Research, research, research people.
I'll give you a couple of keywords and then you can use the search button :)
The keywords are: T-18 and TE72.
