August 12, 200818 yr comment_267823 hi guys, thinking of putting a t series in the 55, blown one bw already and i think this ones on it way out do the diffs have the same tail shaft bolt patern thingo? and if i got a lsd from a ae86 would that fit in a t series form something like a ta22 or ra23? Report
August 12, 200818 yr comment_267832 do the diffs have the same tail shaft bolt patern thingo? and if i got a lsd from a ae86 would that fit in a t series form something like a ta22 or ra23? No and AFAIK No. Report
August 12, 200818 yr Author comment_267833 No and AFAIK No. so i will need new tails shaft then what lsd's can you get for a early t series then? having huge traction issue atm, needs to be sorted out Report
August 12, 200818 yr comment_267843 so i will need new tails shaft then what lsd's can you get for a early t series then? having huge traction issue atm, needs to be sorted out Hi there. I am running a T series diff in my KE30, running 2TGEU I made custom mounts for the spring plates to the diff tube... As for the diff centre. ae86 zenki lsd fit BUT. If u r using a standard open ta22 housing like i have, u need to machine 3 - 4mm off the splined end of ur axels. An angle grinder and an ultra thin disc is what i used... As for the tail shaft, i needed to lathe the centre of the diff flange out to fit the ke 30 tail shaft and redrill mounting holes to suit... As for traction issues i have smashed 2 wis bang TRD lsd so i wouldnt reconmend using them. Save ur bickeys and buy a Kaaz or Cusco Report
August 13, 200818 yr Author comment_267885 cool as, thanks for your help bud, much appreciated=) Report
