February 24, 200521 yr comment_32890 i just want to know..will w55 gearbox from 1g series engine fit in.. 1.20v 4age 2.4age tvis 3.4agze is it direct fit or we have to use back the t50 bellhousing? how about the longshaft? Report
February 24, 200521 yr comment_32892 no, you'll need a custom bellhousing. there are a couple of companies in NZ who make them, ask on garagedori.com Report
February 24, 200521 yr comment_32948 yep...custom bellhousing or adaptor plate...both will set you back between 300-400 theres a guy on the gold coast that makes the adaptor plate...you can find him on twincam.org under Aza510 bellhousing can be sourced from garagedori, dellows or a-spec...mine came from malaysia but i can't remember where you'll need a custom tailshaft also Report
February 25, 200521 yr comment_33096 the best iv heard about is the niteparts bellhousing its $750ish nz.. i can get those. they allow 2 diff slavecyls and use of larger (4agze) clutch Report
February 25, 200521 yr comment_33128 its $750ish nz.. yikes...have you got any photos Mr Revhead? the quality must be pretty darn good Report
February 27, 200521 yr comment_33439 they were made with the idea they would look and act factory, and they do iv got pics, but not with me, I'm on hols at the mo... Report
