Twin Dellorto Linkage Issues (3k)
Hey guys i have searched and searched and found some valuable information, I printed out a range of pictures of the linkages that other people have done eg Kangaroosa One, but am still gobsmacked as too how to set up certain parts of it, so I'm mainly after anyone with DELLORTO's on there K motor to send me certain pics and stuff,
Any help much appreciated!
Thankyou Trent
[email protected]
Thanks man I done alot now and its starting to take shape,
one question when i tighten up the nut on the back carby it locks the carby? hmm, il post piccies of mine when I'm done.
Thanks
Trent
I know that these are not dellorto's but the setup should be similiar
Wow thanks KE20 rolla thats exactly what I needed!
Could you get on of the back carby linkage area?
Thanks
That's how far I've got, I just need some pics of the back linkage, as i think there was some bits missing out my linkage kit as it was already open when i got it :dance:
Cheers Trentuss
My two carbies link together in the middle, therefore requiring only one shaft to operate the two carbs. I take a piccie shortly. Both my webers and the Dellorto set up I had did this. Actually, all three off my Weber set ups are like this. Back shortly.
Oh yeah I know what you mean R, Did you use a redline linkage kit? part number 42-2562?
Thanks mate
Thanks mate
Nope, we threw it together from a hundred yards with what was lying around the workshop.
This set is a pair of Webers, but the Dellortos I had were the same.
As you can see, single rail with a single pushrod.
View from underneath.
Two fittings on each carb work like a tongue and groove arrangement.
Slight scallop to the manifold is required for this arrangement.
You can see it better here on a spare I have....
Ditto.
Hope this helps......
Gee thanks all for the pics!
I got it all done, now just the throttle cable bit. KE20Rolla Could you get some pics specifically of your throttle cable arrangement?, I am trying to adapt the original kinda design off the STD downdraft carb.
thanks guys! :dance:
