Ke20 Suspension- Adelaide
Hey could anyone please tell me the minimum legal hieght of a Ke20 and where its measured from I have heard its from the middle off the hub cap to wheel arch?
also my rear air shocks have perished and the front needs attention, profix have qouted me around 350 for the front and 270 for the rear.. is this reasonable or should i continue looking elsewhere?
Cheers Dean
erm... yeah havent heard that one before :sob:
for qld its the distance from the lowest point under the car to the flat ground,
so you get a 100mm wheel on a pole rolled under your car and if any point
stops it then its too low, not including near wheel areas though.
soon every state will be switching to ncop code as far as i know which
will probably be the same 100mm wheel rule but check it out first to make sure.
rear air shocks? hmmm not as in airbags or anything?, I'm assuming you mean gas shocks
which are conventional gas dampers (ie shock absorbers) these days, nitrogen filled to stop
foaming. these are a normal replacement damper and should cost from around $100 each front
and $60 each rear in parts and a few hours to replace... $300 or so? so $620 total isnt a bad price
for drive in drive out no labour no tools or shed to diy i suppose.
