Super Dooper Idle Help! More Help Needed :)
hey everyone, i've put a weber on my ke70 and have various problems so far
but now have managed to get it idling (if you would call it that)
it has massive jets in it 160 for primary and secondary, not sure what they should have for a 4k does anyone else?
i havent played with the idle adjustment screw yet as it got dark soon after it was idling.
anyway would just like a hand to understand why it is idling like this, if its just running to rich? or some other problem
http://www.soundupload.com/audio/95a7c053gigr833b that is the sound file
cheers everyone
Chester
Edited by chester_fb
ok i thought it was that
umm not sure what kind of weber it is, ive posted some pics if that helps anyone determin what it is
Also it has a tag on it that says "weber 84 DA SB A 4 K 26"
CHEERS MATE! its a ADM 34, now i can get some jets for it
thanks again
chester
its gonna be turbo in the near future :sob:
I'm sure it will be fine under full throttle full boost conditions. If you drive it on the road you spend more time off boost cruising... That's where a smaller carb would give you better economy, responsiveness, and allow the motor to come on boost quicker. A 32/36 DGV would be better choice.
I intend on driving it full boost, full throttle for the time that it is on the road :sob:
ok well i've put smaller jets in, and it still has the exact same problem
anyone got any other ideas?
