August 25, 200818 yr comment_270345 Hi Guys We over tighted one of the bolts and the head came off, we are using stud removers to get it out but it broke off. We need to get the pump off so we can get a better look at the stuck bolt. We removed all the bolts and I think we are stuck on the strainer, is there a technique to get it off without removing the sump pan? If we need to remove the sump pan, is there a way to get off without removing the engine?? Any help appreciated, and urgently needed, thanks so much Mike P.S Also Posted on Toymods Report
August 25, 200818 yr comment_270357 Hi Guys We over tighted one of the bolts and the head came off, we are using stud removers to get it out but it broke off. We need to get the pump off so we can get a better look at the stuck bolt. We removed all the bolts and I think we are stuck on the strainer, is there a technique to get it off without removing the sump pan? If we need to remove the sump pan, is there a way to get off without removing the engine?? Any help appreciated, and urgently needed, thanks so much Mike P.S Also Posted on Toymods You gotta take the sump off. Report
