alright iv put a 4age bluetop out of a ae82 fxgt in 2 my dx and it wont go,
plenty of fuel and compression but when you plug a spark plug into coil lead and crank it theres no spark...... until you let go of the key, then one sparks shoots across the gap.
there no power getting to the dizzy but power at the coil
iv figured out that somethings not plugged in as being the ADD aprentice mechanic that i am i didnt mark out
any wires and after work(and plenty of red bull) just pulled motor and loom out thinking, it should be pretty obvious where the wires go.... how wrong i was
anyway I'm pretty sure everythings plugged in EXCEPT one plug which looks pretty important.
its a white two pin plug(the type with the horizontal top pin and vertical bottom one) and that comes
straight off a 30 amp fusible link off thats on the positive battery terminal, so I'm guessin its needed
so if theres ANYONE :y: :y: out there with a ae82 fxgt or a dx with bluetop out of ae82,
can you pleeease let me no where it goes cos i just wana do sum skids..
cheers
  • 3 months later...
