October 8, 200818 yr comment_280034 i was driving home and it started raining really hard the car fogged up and i could not see were i was going i had to wind my window down and get all wet just to get home what do u recon is the problem with my dimister Report
October 8, 200818 yr comment_280036 are we talking front or rear? If you have no fan speeds it will be fan speed resistor, Rear would probably be a power supply issue/frame return issue.. Report
October 8, 200818 yr comment_280041 with a test light/multimeter check to see you have power on one side where it clips onto the demister bars, the other side of the window should go to frame.. Report
October 8, 200818 yr comment_280042 Fuse?? Your fuel and temp guage working?? Is your KE30 equiped with a demister?? :cool: Are the wires behind the switch plugged in?? Report
October 8, 200818 yr Author comment_280044 Fuse?? Your fuel and temp guage working?? Is your KE30 equiped with a demister?? :cool: Are the wires behind the switch plugged in?? yeah every thing else is working i put a new switch in and that didn't do any thing and yeah the car came with dimister Report
