October 10, 200818 yr comment_280640 Hey. There is a build-up of thick oil where my spark plug leads plug into the rocker cover... what is this indicative of? Cheers. :P Report
October 10, 200818 yr comment_280642 hey all you have to do is get a new little rubber seal or the alloy chamber thing well that's what i done, i went to you pull it and got my parts from there you will have to get a new gasket set if you want new rubbers or chamber thanks myles Report
October 10, 200818 yr Author comment_280646 hey all you have to do is get a new little rubber seal or the alloy chamber thing well that's what i done, i went to you pull it and got my parts from there you will have to get a new gasket set if you want new rubbers or chamber thanks myles I have no idea what that is :P Haha. Got any pictures of it? Report
October 11, 200818 yr comment_280801 I have no idea what that is :P Haha. Got any pictures of it? no i dnt have any pics but ill tell you were it is ok take the spark plug lead off the spark plug get spark plug remover, then undo the spark plug the metel chamber will come out with i then you will see the little rubber ring thats what you need to replace thanks myles Report
October 12, 200818 yr comment_281074 you need to replace the spark plug tube gaskets, should be able to buy them separate to rocker cover gaskets. or replace the rocker cover gasket aswell and do your valve clearances while your there? :wink: edit: Taz_Rx is doing a group buy on what you need. http://www.rollaclub.com/board/?showtopic=24338 Edited October 13, 200818 yr by furryfrog Report
