Hey, how you going guys. I've got a AE100 Corolla (Import). Reverse lights are not lighting up. At the same time the reverse gear status light on the dash is not lighting up and reverse warning tone is not beeping anymore. Could it all be linked together?
Maybe check the plug on the gearbox? might of come loose....
Check the sender from the box, wiring might have come lose or something similar.
If they are the same as the early ones, then unplug the wires (should be a 2 pin type plug) and just link the two together (bit of wire poked in each terminal)
If your lights don't come on, then there is a problem elsewhere. All the switch in the box does is complete a circuit.
