October 18, 200818 yr comment_282321 I'm running a 4K 1300 ke 20 and I can't seem to get the car to start eventually i can but its taking ages like 15minutes of be pedal down and pumping with the choke on and off. I poped the bonnet and i expected the new fuel filter i bought to be full of fuel but its half full so am i right in assuming theres a blockage somewhere in the fuel lines? any advice or tips or the solution would be much appreciated guys or if it could be something else... cheers Report
October 18, 200818 yr comment_282360 Sure there's fuel in the tank...? Preferably not just going by the gauge. Report
October 18, 200818 yr comment_282377 check the pump might be stuffed mine was doing the same thing changed it out from a spare worked sweet Report
October 18, 200818 yr comment_282525 Put fuel in the carby (only a small bit) and then start it and see if it will stay running with the choke out or foot on pedal slightly. I had same prob, turns out the mechanical pump had crapped itself. Just go get a new one, or even better put a electric one in the boot :) Report
