h1_roll4 Posted October 20, 2008 Report Share Posted October 20, 2008 I'm not sure how to change the wiring from the 4k wires to the 4age ones. the 4age alternator has 2 extra wires the two wire plug coming off the fuse box the 4k plug, pretty sure its + and - 4age plug, has the big + wire and 3 wires coming off the plug need to know what the other wires are for. any help. cheers Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted October 20, 2008 Report Share Posted October 20, 2008 Big thick white of the 2 can be used as battery sense, Small yellow is charge light wire, Just need an ignition wire.. has been discussed numerous times before.. http://www.rollaclub.com/faq/index.php?tit..._Wiring_Diagram all the info you will ever need on a platter.. Quote Link to comment Share on other sites More sharing options...
h1_roll4 Posted October 22, 2008 Author Report Share Posted October 22, 2008 uhh I'm retarded when it comes to electrics B- goes to the battery? L- goes to the original alternator plug? S- goes to the original alternator plug aswell? IG- use the power from the coil? Quote Link to comment Share on other sites More sharing options...
Medicine_Man Posted October 22, 2008 Report Share Posted October 22, 2008 yep, will work fine.. Quote Link to comment Share on other sites More sharing options...
