October 20, 200818 yr comment_282900 I'm not sure how to change the wiring from the 4k wires to the 4age ones. the 4age alternator has 2 extra wires the two wire plug coming off the fuse box the 4k plug, pretty sure its + and - 4age plug, has the big + wire and 3 wires coming off the plug need to know what the other wires are for. any help. cheers Report
October 20, 200818 yr comment_282938 Big thick white of the 2 can be used as battery sense, Small yellow is charge light wire, Just need an ignition wire.. has been discussed numerous times before.. http://www.rollaclub.com/faq/index.php?tit..._Wiring_Diagram all the info you will ever need on a platter.. Report
October 22, 200818 yr Author comment_283604 uhh I'm retarded when it comes to electrics B- goes to the battery? L- goes to the original alternator plug? S- goes to the original alternator plug aswell? IG- use the power from the coil? Report
