November 8, 200818 yr comment_288204 ok rolla members before we all get mad about this topic i have searched everywhere all over the site and none the wiser ok my dillema is... I have been given a tacho and i have hooked up the wires so when i put my lights on the tacho light will light up :y: and the iginition switches on but i havent actually got the tacho reving which is the problem i have a solering iron and wires ready to be hooked up what i gather is that i need to earth one wire then my question is does the other wire go to the distruber or what do i hook up that wire too any help would be much appreciated s i have been completely racking my brain for answers rolla members any help would be superb.. ps I'm running a 4k-c 1300 in a ke 20 cheers any help much appreciated Edited November 8, 200818 yr by ke20red Report
November 8, 200818 yr comment_288215 The tacho feed goes to the negative side of the coil (black wire). Report
November 8, 200818 yr comment_288305 Hay mate just done mine today. I have 5in autogage by autometer and hear is the wiring diagram for it. 1. white. wire to 12v dash lightling. 2. red. wire to 12v ignition switch (+). 3. black. wire to (-) on the battery or good engine ground. 4. green. wire to (-) on the coil. O and if this isnt it try and google it or go to the manafacture's web site. Sorry about the spelling and i hope this help's and hope its the same as your cheers Edited November 8, 200818 yr by shauns ke30 Report
November 8, 200818 yr Author comment_288311 thanks thats alot clearer i have the ignition and light wires hooked up so just need one to the battery or do you mean to earth it to the car? and the negative to the coil on the disturbuter.. Report
November 8, 200818 yr comment_288317 thanks thats alot clearer i have the ignition and light wires hooked up so just need one tothe battery or do you mean to earth it to the car? and the negative to the coil on the disturbuter.. Yeah all you need is to get a good earth on the car, and then the other wire left over goes to the negative (-) of the coil. :y: Report
November 13, 200817 yr comment_289614 just for simplicity and my race spec look I have one ground wire and one positiive wire running from my battery to multiple out terminals in the cabin, then I hardwire my accessories and get to use switches, in the past though I just grounded things to bolts inside the car or in the fireall..BIG bolts. Report
