November 9, 200818 yr comment_288391 Hey guys, I'm installing the air con back into my girlfriends ke70 and have a couple of things i'm not so sure with how they run through the engine bay without interfering with other things. I've had a bit of a search and found teddy's "Installing air con into a ke70 that didn't come out from factory with it", but i'm pretty sure i'm missing the hard line that goes from the "out" side of the receiver to the top metal bit on the cooling unit. But just to make sure on how things go, is there anyone out there still running air con in there ke70 that could take a few detailed pics from there engine bay just to make sure i've got it how it's meant to be? So i can suss out exactly what else i need to get or to see what i could possibly use from any other cars around. If you can upload pics here please do, but if not could you please send them to [email protected]. Cheers in advance people. Tom Report
November 9, 200818 yr comment_288425 http://www.ke70.com/Toyota%20Corolla%20Air...nstructions.pdf This should help ! Ted Report
November 11, 200818 yr Author comment_289153 Cheers for that teddy, i now know that i'm definately missing the hard line from condensor to firewall top plug, an i can't use my ae71 lines for some reason so does anyone have any pics for me please so i can use it as a guide as where to run the lines and show me which line i do need for sure. Cheers tom Report
