November 18, 200818 yr comment_291110 hey gues about 2 months ago i bought a corolla ke55 coupe been a bit lazy but i finally got some pictures had some dramas here they are the resistor to the coil was stuffing up > fixed i didnt have high beams the combination switch was screwed got another one and the parks wouldnt come on with it so riped the both apart and made 1 out of 2 not the high beams wont go off > working progress no rear tyres left > fixed the horn would come on by it self when you turned > car fixed it blown head gasket > on order alternator over charging > getting fixed at work key barrel stuffed > fixed got a new one plan for my ke 55 coupe rust removal 4 age 20v with trupets work equip 03 wheels with a hole lot of dish and custom made flares retrimed interior in black small stereo tuff suspesion and big brakes progress on getting my dream headunit in with dvd player amp and 2 speakers sigma 14" wheels on the rear woot more speed got front black wheels in garage no tyre left on them cheese cutter fronts Edited November 18, 200818 yr by ballzy Report
November 18, 200818 yr Author comment_291113 the engine a bit dirty rust yuck Edited November 18, 200818 yr by ballzy Report
December 8, 200817 yr Author comment_296311 hey guys up date my vacum hose switch didnt work so i just connected it straight to the carby sad and stupid teenager i just found out my licence will be suspended for 3 months :P so hopefully ill get some heavy work done to my car over that time I'm at the stage just trying to get her running smoothly Report
December 8, 200817 yr comment_296313 like your car. also got similar car a ke35. in the same sort of stage of getting things going alot smoother. would like to know how you get on with the head gasket. Report
January 4, 200917 yr Author comment_304074 hey guys got some newish rims they measure 15 inch by 6.5 made by impul found at the wreckers $80 for the set and dad took my car for a drive and it broke down in double lines glad it was only the points but my dad bent the drives door hinges and the door wouldn't open without damaging the front gaurd did a little home panel beating and got it to work i just need some advice should i do work to the 4k and get some power out of it or should i do a 4age conversion if 4age 16v or 20v ???????????? please give me some advice i just would like some opions on which way i should go thank you ballzy Report
January 4, 200917 yr comment_304121 I'd say the best advise anyone could give you right now would be to keep your father away from the car. :y: Report
January 5, 200917 yr Author comment_304479 yeah he wont be but he offered take it to a panelbeater and get new paint were the damage is so something good came out of it Edited January 5, 200917 yr by ballzy Report
