:P
Full race 4K engines + spares (in USA)
I am selling two Full Race, high compression Toyota 4K engines and related spares. 14 to 1 compression ratio with 0.040" overbore race pistons. Both engines are dry sump engines. 7mm valve stem size with race springs and titanium retainers and matching locks. Pictures are available. Both are running and were maintained. Both were using the Weber 45DCOE carbs.
#1 4K engine has Ross high compression race pistons, Kent camshaft, lightened/balanced crankshaft, Carillo con rods, TRD oil pump and TRD oil pan. Has Electromotive distributorless ignition wheel and pickup. Can still use distributor for ignition.
#2 4K engine has Arias pistons high compression race pistons, lightened/balanced crankshaft, Carillo con rods, Crane camshaft, SCP (Stock Car Products) oil pump and TRD oil pan. Has Electromotive distributorless ignition wheel and pickup. Can still use distributor for ignition.
Spares:
Box of TRD oil pump parts.
Spare oil pump and water pump gilmer belts.
Used race valves.
Several sets of new rod, main and thrust bearings.
1 adjustable timing gear.
1 TRD timing wheel.
4 into 1 Exhaust system.
3 race camshafts.
3 TRD race camshafts with damage - repairable.
2 prepared blocks, one 4K and one 5K with ARP hardware.
1 set +0.040" 4K race pistons & rings.
1 set +0.040" 5K race pistons & rings.
Custom 4K/5K piston ring compressor.
3 Carillo con rods.
1 new race prepared fuel injected head with valves, guides, seats. Needs port & valve seats cut.
4 sets push rods.
3 sets race valve springs.
3 sets titanium valve spring retainers.
3 sets valve locks.
2 sets 4K solid lifters.
2 sets 5K solid lifters.
4 starters. (2 gear reduction and 2 standard)
1 5K bellhousing.
Some stock blocks, cranks, cams, flywheels.
Looking for $5000 USD for everything packed safely into a wooden shipping container.
