Tham Posted December 8, 2008 Report Share Posted December 8, 2008 My KE70's 4K engine's cooling system seems to be having a slow leak, about 100 cc a day. The expansion tank level would go down about half to one inch every morning. Several mechanics searched high and low for the source of the leak - water pump, expansion tank itself, radiator, hoses, head gasket, etc, but couldn't seem to find any. They ran the engine at idle at operating temperature for quite some time, then switched it off and let it cool down. The level in the expansion tank, as well as the radiator cap, stayed constant. The radiator remained full up to the cap level. However, the expansion tank level would go down half to one inch by the next morning. The radiator remained full, meaning it had sucked off the loss from the expansion tank. One of the mechanics suggested that maybe it was minor head gasket seepage or crack in the engine block which could not be detected, or even a small core plug leak which was out of sight, perhaps in the rear block housing with the gear box. Might pouring half a bottle of Wynn's Radiator Stop-Leak No. 68627 help ? I've heard that Holts Radweld tends to clog engine and radiator waterways. Thanks to all the good people here. Quote Link to comment Share on other sites More sharing options...
furryfrog Posted December 8, 2008 Report Share Posted December 8, 2008 did any of the mechanics try to pressure test the cooling system? Quote Link to comment Share on other sites More sharing options...
DearmanKE Posted December 9, 2008 Report Share Posted December 9, 2008 although stop leak isnt usually recomended because it can block up bits in your radiator making your cooling system less effective i had this same problem in my old ke70. i used stop leak and it worked fine, the car would get a bit hot on idle, but it did that bfor i used stop leak anyway. so yeah Quote Link to comment Share on other sites More sharing options...
WinKE55 Posted December 9, 2008 Report Share Posted December 9, 2008 Pressure test the cooling system. I am pretty sure you can get a dye that you can put in your cooling system and I THINK you need a UV light, it will show up the leak in no time at all. As you should know, if the car is filled up when hot, the water inside is already expanded a bit so in a cold morning the water will come down a bit. Though what you say is a little too much for that Try looking under your engine oil cap, have a look to see any bubbles, thick milkshake kind of substance. If so, then head gasket is blown. Quote Link to comment Share on other sites More sharing options...
dashills Posted December 9, 2008 Report Share Posted December 9, 2008 hey , is your right hand front floor wet if so its your heater core . the same thing happend to me a about 9 months ago so turn your car on and turn the heater on once its hot check for water on the floor good luck with that one Quote Link to comment Share on other sites More sharing options...
ke30Rolla myles Posted December 9, 2008 Report Share Posted December 9, 2008 the same thing happend to me when i changed my engine i split the heater hose and my floor filed with coolant so i blocked the hose off made it run back into it self but now i have to keep topping up my water in the coolant, every time i start my car it sounds shit and sounds like there is water int he psitons then once i rev it all the watr clears it runs like normal i have replaced the head gasket 2 times but seems to be sitll doing it:( Quote Link to comment Share on other sites More sharing options...
DearmanKE Posted December 9, 2008 Report Share Posted December 9, 2008 cracked head? Quote Link to comment Share on other sites More sharing options...
WinKE55 Posted December 9, 2008 Report Share Posted December 9, 2008 hey , is your right hand front floor wet if so its your heater core . the same thing happend to me a about 9 months ago so turn your car on and turn the heater on once its hot check for water on the floor good luck with that one That could be pretty good idea to check to. Can't believe I missed that! :D keep us informed on what it was =] Quote Link to comment Share on other sites More sharing options...
philbey Posted December 10, 2008 Report Share Posted December 10, 2008 Sounds like a fairly minor head gasket issue. I've had them where they are using water, but show none of the other symptoms of HG leakage for some time. I drove my CA18 turbo for months suspecting the gasket was leaking (similar issue, used small amounts of water) but only occasionally would I see excessive steam out the exhaust on cold mornings. When I finally got Cappucino froth in the radiator, I changed it. I wouldn't worry about it that much until you see that. Quote Link to comment Share on other sites More sharing options...
DouggehKE30 Posted December 12, 2008 Report Share Posted December 12, 2008 On my 5k I kept losing water for ages I had no idea where it was going, presure tested a couple of times, then pressure tested it again and suspected the welsh plugs, took off the manifold and found the the block had a decent crack down the side, thus leaking water. But it only seemed to leak every now and then. It was easy too see mine, as it had large rust stains down the side.>Pic of crack<..allso next page. Hope this might help narrow it down. Quote Link to comment Share on other sites More sharing options...
philbey Posted December 12, 2008 Report Share Posted December 12, 2008 Probably an engine temp issue, it may close the gap due to expansion of the block etc. Quote Link to comment Share on other sites More sharing options...
Tham Posted December 12, 2008 Author Report Share Posted December 12, 2008 Thank you for the good and very useful information, everyone. The people in this forum really know their stuff. I'm from Malaysia, so none of the cars are fitted with heaters here. Both inlet and outlet pipes (to the left and right of the water pump) are plugged off with 15 mm rubber plugs. The same with my Opel Gemini years ago. These plugs usually have to be replaced every two or three years. Most mechanics in Malaysia are quite "primitive". Other than those big service workshops belonging to dealers or assembly plants, hardly any small-time mechanics have tools like cooling system pressure testers or torque wrenches, let alone radioflourescent dyes or UV lights. One of them did have a pressure tester, but he had misplaced it. Well, I took it to another "primitive" mechanic two days ago, who still repairs my engine every now and then. He and his apprentice, using only their eyeballs, looked all over the engine very carefully for the leak. His appentice boy crawled underneath, and finally managed to spot what appeared to be some wetness lower down the rear of the right side of the engine block, below the intake/exhaust manifolds. Looking further up, it appeared to be coming from the last core (welsh ?) plug from the end of the block.The plug was rusty. From above, this plug was blocked from view by a heat shield. Replacement it was quite a major job. The starter and manifolds had to be taken out to reach this plug. The plug cost just M$5. He hammered the old plug a few times, it came loose, and the coolant burst out, which looked quite murky and rusty even though I am using good "Valeo" brand coolant (thought these had good rust inhibitors ?). I forgot to ask him to insert a hose into the radiator cap to flush out the rest of the old coolant. Anyway, the next day, looking at the expansion tank, the level appeared to have dropped half an inch again. I'm not sure, this could be due to some small air pockets still being left in the block after they had filled up the radiator with new coolant and water. Or the head gasket might also be having a minor leak, as Philbey suggested and experienced. I also occasionally notice some condensation from the exhaust on cold mornings, or cold rainy days. Thank you again for all the help. Quote Link to comment Share on other sites More sharing options...
