Hey Guys,
Just got myself an ae92 and I found out that all my tail lights are gone so I changed the bulbs etc. Was working fine after replacement now they are all off again :D
if i got the headlights off I got brake lights if i turn it the headlights on I got nothing.
Would it be some blown fuse or more likely some wiring problems?
  • 4 weeks later...
Hey Guys,
Just got myself an ae92 and I found out that all my tail lights are gone so I changed the bulbs etc. Was working fine after replacement now they are all off again :y:
wiring problem definitely... check all wiring around combination switch, brake light switch, tail lights...
also if you have a trailer plug harness make sure that it isnt damaged, as if its been scraping and now wires are exposed, this exact problem will occur
