I'm trying to install a towbar on my van at the moment, and it doesn't have a harness for the trailer. I found a cable that had been cut off, it has 5 wires in it. Anyone here know much about trailers? not sure if it is a harness or not, and if it is, what wires to use when i connect a plug. any help would be appreciated :dance:
If you don't have a plug yet then work out what connection you would want to suit your trailer. round or flat plug small or large. All should come with a wire diagram.
I have the wire diagram some where for a 7 pin plug. let me know if you need it.
Thanks that does help, I'm not sure which one to use, all the new cars i work on these days use the 7 pin flat socket, but mine only has 5 wires, I'm guessing thats the standard, so is it compatible? I might have to get a workshop manual for my van so i can figure out what wires are what.
