April 7, 200521 yr comment_38447 bought it off of ebay for 80 bucks usd. The guy said it was for a pre '74 corolla......i asked specifically if it would fit a '69. got it, put it on yesterday, had to cut 1/2" off of the motor mount plate, finished it up today. leaking at head....that'll teach me to try to reuse old gaskets..... i don't really notice any difference, just is louder at the twice pipes any advice? Report
April 7, 200521 yr comment_38457 You won't notice much gain now until you reduce your intake restrictions (head, inlet system) and stuf like that what sized exhaust system did you connect it to? Report
April 7, 200521 yr comment_38499 if you put a camshaft in your motor bigger than 260 degrees with the stock exhaust manifold, you will get inlet reversion and will need to put extractors on just on its own, it's proably making a bit more power and will sound nicer, if you have a full 1.5" to 2" exhaust it'll make a few more horsepower, but it's going to throw you back in your seat or anything Report
April 15, 200521 yr Author comment_39368 well, i just got back from a 400 mi trip; at 3,000ft altitude i notice a SLIGHT increase in power. down around 1,500ft altitude it's more like 5hp. i can DEFINETLY feel it. mileage is the same, but it is WAYYYYY louder i am using 2" exhaust. i was thinking about packing some steel wool into the tail pipes...... i am running a stock starlet 4k-e system, so a big cam is OUT. i would like to know how to convert it to a map sensor system......any help? Report
