I'm putting some lowered springs in my KE70 and I need to get the front struts out to change the springs over.
I've ran into a little problem and can't find a quick solution. On the strut, the small hole where the brake lines run
through it, don't have a little slit to slide the lines out of (as I thought it would), and I don't want to undo the brake
lines and have to bleed them when I put it back together. How can I get the strut out without playing around with
the brake lines?
Edited by seabiscuit
Get a pair of tin snips, clip the top edge of the bracket, bend bracket, remove brake line.
Install is reverse.
I thought I'd have to do this. I didn't want to decimate it.
Thanks very much! :(
Update!
The 3mm steel was difficult to cut with snips, so I used a hacksaw. But I got the strut in and out "easily" enough.
Putting the clip back in when re-installed was a little difficult as the bracket wasn't perfectly straight.
If you're not taking the strut completely out and are just getting it out of the way, you can also remove the brake
calipers to give yourself a little extra slack on the lines, rather than cutting the bracket.
Mission complete!
