January 11, 200917 yr comment_306582 My window winders are doing the normal jam thing as I wind down. A little pressure on the glass helps. I have replaced the drivers front one before. I have two spare rear dorrs and was wondering if anyone knows if you can swap them? Also, what is the best dry lube to use on the mechanism? And yes, I went and bought that special tool......... Cheers PM Report
January 11, 200917 yr comment_306584 You can buy Wax sticks, They work good enough for window winders. Report
January 11, 200917 yr comment_306634 My drivers window winder is currently stuffed at the moment too. Gears have all been stripped some how. It'll just go up to a certain height and the winder will keep turning. Down isn't a problem most of the time. Putting the rear door winders up front won't work. The front doors are a little longer and the way the glass goes down is not right from memory. Report
