hi guys,
I'm using a VL/Bosch hi pressure fuel pump and a Lift pump from a VS.
Just need to know what Amperage fuses i will need to run for each of them. Even if anyone knows what fuses they run from stock.
EDIT:
Thanks Darren (KE30 KE35 KE55) for the help. 15ampers should do
Edited by SLO-030
hi guys,
EDIT:
Also Make sure you get a quality fuse holder, as some are poor quality and will fail.
Luc said to Use just one larger fuse on the larger 12 gauge cables rather than 2 15 ampers after the 12 gauge drops to 2 smaller wires. a larger one at the star of the 12gauge will blow if any of the 12gauge shorts out underneath the car. Or i could just run 3 fuses.
