Hey just wondering if someone had a wiring diagram for a 4k electronic dizzy the one with coil and external igniter and resiter. Thanks any help would be helpful as i am confused where the wiring has to go and want to make sure incase i do it wrong.
sorted out wiring just wondering if someone could help me with the vacuum advance,
on the mech dizzy theres one outlet for a tube to go to it but the electronic one has two and it came with a tube going to both on dizzy and don't know where to put pipe for the advance
I had the same prob, with the 4AC engine, Mech 1 pipe; Electronic 2 pipes.
One hose goes to "Ported-vacuum" and other goes to "Manifold" -vacuum.
But if you put both hoses to "Manifold-vacuum" you will get better fuel economy!
Oh cheers for that info :dance: ohh also think my wiring was wrong as i can't get spark from the coil igniter so if anyone could help me with a wire diagram for the elec dizzy it would help very much cheers
Hope this helps. Sorry about the quality, its from my camera because i don't have a scanner.
