Ke10 Speedo Not Working
Hey guys the speedo on my ke10 has stopped working recently, the miles travelled counter still ticks over but the speedo stays at 0. ive checked that the cable is still connected at the dash and followed it along into the gearbox and its still connected to the box and hasn't snapped.
I'm unsure what else to check for :P.
also my reverse lights don't work, do ke10's run some sort of reverse light switch? or what triggers the lights to turn on? i had a look at the globes and they are not blown. is there a fuse for the reverse lights?
cheers for any help!
The back up light switch looks like a big nut with two pins coming out of it, and is located at the back of the gearbox extension housing (the back bit the gear lever fits into).
The car only has 6 fuses so if it was a fuse, there would be other stuff not working.
sounds like your speedometer is broken?
ring person below and ask how much to rectify problem.
Rod Brereton
45 Mitchell Street - PO Box 1378 Shepparton Victoria 3630
Telephone: 03 5831 2670
Email:
[email protected]
Telephone: 03 58216254
Fax:
03 5821 6254
www.sheppartonspeedo.websyte.com.au
Edited by drc_ke20
