Removal Of The Ignition Barrel From Ke35?
a few days ago some lovely people broke into my ke35, and broke off a drill piece in the ignition barrel in my ke35 does anyone know how to get the barrel out so I can replace it?
cheers, cactus Bob
sad to hear about that. i don't know how to pull it out tho. i know how things can seem easy but arent really.
good luck. hopefully someone in the know chirps up soon
  • 3 years later...
This is actually dead easy. Remove the plastic surrounding the ignition barrel, wiper switch etc. Remove the steering wheel. You will see a small hole facing towards the drivers seat in the ignition barrels housing about 1/2 cm from the end. Place something that will fit in the hole. Give it a firm tap with a hammer. The pin that holds the barrel in should be pushed into the lock, which should now slide out with little effort.
