March 31, 200917 yr comment_332720 Hey, Can anyone tell me of some nice looking stock steel rims that l can use on my KE20? I am looking at 14 X 5.5's. Obviously there is the std option but are they any other makes or models that would suit? Thanks for you help. Report
March 31, 200917 yr comment_332725 can't get them mate, lots of mazda 13" wheels will fit but their mostly 13 x 4.5 Other options are 'frank specials' which are celica 14 x 5 rims re-drilled to 4x110 bolt pattern, and ive heard of a few people running some 4 x 108 rims with success? I'm not sure on that one. Ive got 14 x 5 Steelies on my ke20. Report
March 31, 200917 yr comment_332726 the only other cars with 4x110 PCD i can think of were the old mazdas. i think they changed the stud pattern around the series 2 RX7 so anything earlier than that should have the correct PCD but i don't know about the offset. EDIT: i think the 4x108 rims are from some euro car and ive heard they can snap studs. personally i wouldnt use them. Edited March 31, 200917 yr by godlovesugly Report
March 31, 200917 yr Author comment_332731 can't get them mate, lots of mazda 13" wheels will fit but their mostly 13 x 4.5 Other options are 'frank specials' which are celica 14 x 5 rims re-drilled to 4x110 bolt pattern, and ive heard of a few people running some 4 x 108 rims with success? I'm not sure on that one. Ive got 14 x 5 Steelies on my ke20. Thanks for that, are your '14 X 5 Steelies' Corolla rims? Report
March 31, 200917 yr comment_332746 Thanks for that, are your '14 X 5 Steelies' Corolla rims? Their Celica rims as fas as i know, came off a RA23 or RA28. Although i think later corolla rims such as Ke70 wheels are very very similar. Report
March 31, 200917 yr comment_332749 yep the most easiest way is to get some 14" RA28 Celica stockies and re drill em. unless you can find some Mazda R100 stockies hehehe good luck!!! Report
March 31, 200917 yr comment_332753 yep the most easiest way is to get some 14" RA28 Celica stockies and re drill em. unless you can find some Mazda R100 stockies hehehe good luck!!! You'll pay more for R100 stockies than most ke20s! Report
March 31, 200917 yr comment_333032 its the early saabs that had 4x108 PCD but don't even think about it becaus as stated you will snap off the lugs. Report
