scottiriver Posted April 3, 2009 Report Share Posted April 3, 2009 Hi everyone. I have a KE70 1982 and when i turn on the lights the high beem doesnt come on. when i flip towards the steering wheel then it comes on but when i flip back it doesnt. the lights are on when i try. thanks Scott Quote Link to comment Share on other sites More sharing options...
drc_ke20 Posted April 3, 2009 Report Share Posted April 3, 2009 sounds like your combo switch needs replacing.expect to pay about $40 on one of this from a wrecking yard. Quote Link to comment Share on other sites More sharing options...
Banjo Posted April 5, 2009 Report Share Posted April 5, 2009 Definitely the combo switch, if the high beam comes "on" in one position, but not the other. Unfortunately, this is one of the weak points in these early Corollas, as the full high beam electric current passes through, & is switched by the combo switch on the steering column. There is no relay interface in between lights & switch. The switch contacts are pretty small & distort or burn, with high electric loads like those from the high beam. Bear in mind that the one you get from a wreckers will also have seen service. I have been able to save a couple over the years by cleaning & bending the switch contact arms. It's worth a try, if you've got a little time & patience. The ultimate solution is to insert a relay betwen the switch contacts & lights, so the the combo switch is only switching the small relay current. I've done the mod to one of my Corollas, and it works perfectly. The other benefit is your lights will be brighter, with no voltage drops across the combo switch contacts & all the wiring & connectors between lights & switch. Always mount relays close to the lights & run a fused supply to the relay directly from the battery. I'm just about to do the same mod to my KE-30. Cheers ! Banjo :y: Quote Link to comment Share on other sites More sharing options...
