T18 3tc Wiring Diagram Help!!!
Hi,
I'm currently putting in a 2tg with twin carbs into my T18 and have come accross a problem...
I'm in need of a wiring diagram for a T18/TE72...
in particular the engine bay diagram...
i need to wire up my coil, as the standard coil wire's were cut out when i converted to 4age...stupid wiring guy did it without telling me...
this is one of the last things i need to get the car running
any help is appreciated
Cheers
Hi,
Cheers
I'll have a look through my Haynes manual for mt TE72 and see if i can hook you up with something... I'll see if i can scan it and post it up, or if not, pm me a fax number?
still need help with this...
even if someone with a T18 can just expose the wiring going to the coil and then take some photos that would do the job...
cheers
