Hey guys!
I've got a problem with my high beams, when i pull the indicatoir stick towards the wheel the high beam works when i push it forward to turn off low beam and on to high beam the high beam lights go out. The parkers and all other lights stay on but just don't seem to have high beam unless i pull the stick towards the steering wheel which is getting really annoying driving down the road with one hand on the indicator lever and one hand on the wheel.
I've checked numerous amounts of wiring diagrams i have but can't seem to find a relay of any description, any ideas?
The KE10's didn't have a headlight relay so i assume the KE11 is the same.
So i would check the connector plug into the stalk for a power output on high beam if no out put stalk is no good.
If there is an output problem is in between plug and lights.
