vagen Posted April 25, 2009 Report Posted April 25, 2009 flushed the rad but not the block hmmmmmmm if the rad was blocked what does the block look like.............. Quote
redae71 Posted April 25, 2009 Report Posted April 25, 2009 get your mechanic to put a TK tester on it, it checks for exhaust gases in the coolant, you could have a cracked head which would explain the symptoms your describing, as the head heats up it expands and if there is a crack there it will open up. Quote
tstylez Posted April 25, 2009 Author Report Posted April 25, 2009 ok so i'm guna replace the thermostat and radiator and hopefully this will help thankyou for all your help and suggestions so far =] Quote
tstylez Posted April 25, 2009 Author Report Posted April 25, 2009 (edited) get your mechanic to put a TK tester on it, it checks for exhaust gases in the coolant, you could have a cracked head which would explain the symptoms your describing, as the head heats up it expands and if there is a crack there it will open up. yeah i think that was one of the problems, think it's been fixed. Edited April 25, 2009 by tstylez Quote
tstylez Posted April 25, 2009 Author Report Posted April 25, 2009 flushed the rad but not the block hmmmmmmm if the rad was blocked what does the block look like.............. the block was flushed, but not professionally and it was fairly ******. thanks for the reminder gotta get someone to do that Quote
