A Little Help If Someone Can =]
ok so i recently purchased a 94 csi hatchback for dirt cheap
and i knew it had engine problems
i took it to a family friend who is a mechanic and we thought we found the problem
put in thermostat
new head gasket
new hoses
new water pump and i still have the same problem
whenever i take it for a little bit of a thrash it overheats on me
does anyone know what could be the problem?
is it the engine? it's only done 160,000km as well
no matter what i seem to do it just goes back to the same thing
would an engine swap solve this?
if so what is recommended
if someone could help me out it would be appreciated
thanks
put in thermostat
new head gasket
new hoses
thanks
radiator flush...could be blocked ?
yeah i did that as well. it was fairly blocked lol. everything seemed fine till i got it home. then the temperature gauge jumped up
it's fairly frustrating
and the only response i got from the mechanic was 'drive it normally'
i've driven older vehicles with more kms on the clock and i've never had it happen to me before
if you have flushed your radiator already check your thermostat it could be sealed shut!
it's an automatic
i was abit blunt on the details
so i'll add a bit more
so its a 1994 corolla csi ltd hatch
and it had engine problems to begin with
so first just flushed out all the old water it was all orange, clearly from the owner running it on water all these years
so waited till it wasn't so bad
then installed a thermostat as it didn't have one previously
and new head gasket as the old one was pretty much non-existant due to the corrosion
all was well for maybe 30-40 minutes
drove into the city and then one of the hoses burst because running it on water destroyed it, so i bought new hoses
installed them
then took it back to the mechanic and he noticed that the water pump was fairly battered so he replaced it
and at the same time he used that solution to flush out all the bullshit that could be sitting there
then drove it home it was ok. went to pick up a mate and noticed the temp was flying up again
one of the welds in the pipes was f@$ked, leaking everywhere
so took it back to the mechanic and he fixed that
i got it back today and all was well till literally 2 streets away from home
i punched it on a round about and when i left it, the temp jumped up again
got home, checked under the hood and it was just bubbling, no leaks at all.
i looked at what some of you have said and i'm guna take it into consideration
but is it possible that due to everything else being corroded by long usage of water that the radiator could be in the same state as some of the parts were? so should i replace the radiator?
or could there still be a blockage somewhere?
or is everything just so far gone that i should just look for a new engine?
i was actually considering to upgrading to a 4A-GZE, but if it's not the engine and it's something else screwing up on me i don't know if i want to spend stupidly
any advice is appreciated thank you
Does the fan work?
Does the fan work?
yeah the fan works fine
everything seems to be fine untill it cops a bit of a beating lol
but it's not even an extreme beating, i drove it for like 20 minutes today giving it every so often to check if everything is ok and it was fine
till the home stretch
have you checked the thermostat to see if it is sealed closed?
yeah i'm checking that tomorrow morning, hopefully that can resolve something =]
bubbling? bubbling where?
cheers,
Slapper
cheers,
Slapper
i really don't know the name of it lol
that white plastic looking container
coolant overflow bottle?
i believe so lol
the whitish container on the right side
i'm not too sure about the terms =[ lol
it was just bubbling and boiling
i'm most likely changing the thermostat in a short while
and if that doesn't fix it
i'll prob replace the radiator
could that be it?
