Everything posted by mungi mods
How To Make Ke70 Adjustable Trailing Arms?
allows for pinion angle as well as centring wheels in the arch
camry rear arms are on car adjustable with a little work they fit inside ke70 arms making cheap on car adjustable arms... ive made both upper n lower as well as panhard rods.
ive made on car adjustable arms .. its easy camry arns into cut.n.shut ke 70 arms
Daniella The Delivery
cheers dave its ve commodore silver base with 5 coats of straight metal fleck and 5 coats of clear all 2 pac.. all done by me at work in 3 hrs..
N00B Ke70 Panel Van Questions.
check out my ride thread for ideas..
rear reset leaves ans add a leaf cost 240 front ae86 struts /coilovers wheels i.have personally run 15x9.5/ 15x10 with 225/45/15 all round anything is possible dash ke70 xx tacho dash fits and is an improvement also give you a proper glovebox mine has a full sedan dash with centre console fitted
all mine.. at some stage this year..
The Rwd 2Az-Fe Thread.
off load it somewhere
did someone say wheels.. i thought i heard flares mentioned too ;) ra60 tailshaft?
What Wheels
i had 15 x8.5 -6 under mine with lightly rolled guards
What Wheels
got you another pair of centres :-)
What Wheels
yup still skinny ..:-)
What Wheels
E30
location phone number ? waiting for pics...
Track Width
no engineer will do a certificate to increase track... thats why everyone does wheel tubs to go large
Bolt On Flares
try weld on first if you ʞ©$ɟ it then bolt ons same amount of work to do bolt ons but more popo attention
Track Width
track is measurement from centre of wheel/tyre to centre of wheel /tyre. your allowed to increase track by 25mm max.. i run 100 mm increased track on my ke70 and have had no issues from the popo .if your wheels poke they will rape you.
Bolt On Flares
weld ke70 front arch to rear then ...25 mm bigger flare straight up.if its that rusty fix it properly and get rid of the rust.
Bolt On Flares
you can hand flare stock guards 25mm easy as less drama more clearance cheaper...
