7K For Racing
is the 7k suitable for club autocross and khanacross. if so how much work is needed on them, can somebody give any ideas on how to go about it. run a ke-20 with 5k at the moment need a bit cubs but like to stay with k series. hope somebody can help thanks cheers mick
Heeelps
balaiz just replace the thermostat housing,it bolts to the head.the water pump is below that with the fan bolted to it. water pump bolts to the block. cheer mick
Ke70 4K Won't Start ?? Help
if you are getting spark, check the fuel pump and fuel pressure.
Need Help For Club Rego!!
your car has to be in a roadworthy condition, some clubs will ask you to attend two meetings a year others more. since vicroads changed the permit system. everybody abuses the system, you don,t have to be going to or from club events. or club related activeties thats why there are so many club rego cars now, its $ 180 for 90 day log book or $80 for 45 day log book. and log book must be filled in or its a $600 fine makes normal rego cheap. cheers mick
Thoughts On A 3Tc Into A Ke25
ke-25 rolla 3t crank will fit in a 2t block, 2t block has narrower crankcase skirts than 3t. 3t crank in a2t block you will punch ahole in side of block. 2tg head will fit a 3t block you will,need timing cover, timing chains,chain idle pully,dummy camshaft that drives distributorand fuel pump. if you do this youwill need to knock out the last two cam bearings in the 3t block turn 180 degrees knock back in to stop lost oil pressure. 2t-1600 bore 88.5 mm-1750 3t-1770 bore 88.5-1980. when you adjust the valves in the head if it is off the motor, do it one cam at a time other wise you will bend valaes on overlap cheers mick
Ke70 Khana Car
lachy hydraulic hand brake best thing you will ever do. cheers mick
Te-25 Or Te-27 Historic Nc Racer
snot35 can the papers be shown one at a time and englared thanks for your help, all of you cheers mick
ranko-87 is it possible to get a bit of a run down on your build thanks. cheers mick
crostek, is it possible to download a copy of your papers it would be great if you could. cheers mick
Ke11 3K Distributor Identification Help.
the new cap might have bosch number, but its for a nippendenso dist. you have bosch dist in your ke-11 take old cap with you. get one the same then get points and rotor to suit. cheers mick
[Cranke10] 1969 Ke10
cranke 10 what model lancer was the alternator off please. do you have any info on your up righting of the motor thanks cheers mick
thanks for your help fellas will check it out cheers mick
would like to bulid a te-27 for group nc, a toyota mechanic at muscle car masters said they came out here as te-25. i though they were te-27. you can bulid replicas. anybody know who i can contact, about information be it in the club or at toyota. hope sombody can help. cheers mick
What Wheels
need ideas on what wheels to run on my ke-25 resto project. i was thinking of running 15 x 6 superlites or 13 x 7 rebel road wheels, 205/ 60 tyres might be a problem for 13 inch rims. cheers mick
Oil Selection? For A Fa 3K Race Engine
castrol edge 10w-60 run it in my 5k at auto cross revs 7-7500 all day no problems cheers mick
Mick E
