mungi mods
Everything posted by mungi mods
  1. i'm in heritage park and could weld in some plates for you if you were keen....
  2. had a 1uz in a ke 70 panel van and it fits....
  3. that's how i knew where you lived....STALKER ALERT !!!! lol
  4. i don't like bolt ons etc because it limits suspension travel unless you run insane stretch... will be running 15 x 8.5-9.9 rims with a minimum of a 225/50 so need travel most of my work takes place out of sight inside the wheel arch you will definitely know the guards are flared when it's finished though as you can see in pics diff is hard on the chassis rails meaning full suspension travel.. only place to set your flares from IMO try to retain as much of the factory look to attract less attention although the rims will probably attract plenty will be adding a lip around the arch ( about 1 inch to give the affect of the car being lower than it actually is i did these ages ago and the owner fitted 15 x10 -6 superlights with 205/50 under them made these on car adjustable panhard rods and trailing arms for same car inside the wheel wells ....gain an inch without any visibility on the out side
  5. fixed today yeaaaaay clearance is minty fresh made all the patterns for door and will be adding steel to lip to "lower "the car further
  6. not HAPPY Jan. broke the F#*KING welder oh well gaffer tape for the win car is back in daily driver mode hope the fuzz don't see me !!!!!!!!!!!!!
  7. Flare job started today with 1 inch "tub" job thrown in for good measure... Ghetto Backyarder styles ... please no flaming.. need to make some more on car adjustable trailing arms... a job for tomorrow have lots of pics will do a tech article if anyone is interested... obviously not even close to finished but you get the idea
  8. Pics powdercoated centres in "bright white " 1 day turn around and $60 for sandblast and powdercoat ...good value slight front and rear flarage needed to fit nicely ... approx 10 mm front and 50mm rear... front meshie on the rear yes they are SSR mk 2 r "r" the second "r " is for RACE ( ie extreme lightweight) I like my wheels and try to find some nice ones then when i get sick of em i sell em and get some more
  9. 2 hrs work from f@$ked to gleaming...still not quite there my polishing wheel decided it didn't want to play so they aren't actually" polished "yet just with a cutting compund ..that said still can see yourself in then reflection :| lavarack at eagle farm dropped off today collect tomorrow :D need to bolt em on so i can get an idea of flareage then they will be back apart and frankenstiened into a 8.5 or a 9 or maybe even a 9.5 this will give me the outward offset for clearances etc.... there plenty of room inboard for more rim n tyre... waiting for the mk 2 's ...took them to a guy in slacks creek .....seems pretty switched on.$120 a rim perfectly straight will let you know when i get em back as to quality for future reference
  10. to to getting there centres will be back from powdercoating tomorrow and fitted up more pics then
  11. buy 3 piece rims( ssr volk most good japansneezy rims ) split them and buy wider sections to replace the narrower section ...hey presto wide rims with wicked offset at a vastly reduced price i had a pair of factory 15 x 9.5 -12 SSR mesh rims which i sold for $1200 without tyres these will be vastly cheaper...
  12. meshies... were 15 x 6.5 +13 purchased from Roo.... thanks!!! now fully reversed and in the process of being polished to MIRROR finish stage 1 only complete "not yet polished" only sanded so far with 40 to 600 grit max dish will be splitting these and making them 8.5 or 9 inch wide with "new" Inner sections sandblasting and painting centres .....maybe bright white should have my ssr's back from having a ding straightened by Friday .. mount wheels on Saturday to see how wide i need to go
  13. yeh it's not bad.. cutting will commence on Saturday..... will be copping a respray once body mods are done.....
  14. 3/82 flat front ke70 xx Now.... 4k 5 speeder open wheeler cut super low King springs with short stroke shocks Corona 14 in rims pairs 15 x 7.5 ssr mk2r"r" 15 x 10.5 Meshies 15 x 9.5 Meshies 15 x 7 SSR reverse mesh 15 x 7 Advan oni's plans SR 20 DET 5 speed Rt142 Disc brake rear Cage race seats n harnesses wide body conversion /seriously flared guards various yet to be disclosed body mods coilovers and better ride control updated as i feel fit
  15. $1200 for recoo'ed bottom end $600-1000 for recoed cylinder head with all clearances set.. $100-150 for all new hoses and radiator flush and clean
  16. rears are + 60mm Fronts are + 90mm will take a 15 x 10 -6 with 205/50/15
  17. thought you would recognise the car.......... np talk Sat
  18. i'm sure I will....
  19. like this..........
