lower control arm to body pivot pins might be able to get these from pedders?
custom adjustable threaded lower control arms also
and yeh like mentioned the strut tops that are adjustable if they make them or you might need to get them made ?
No, neither of these options are going to be very easily acheived on a KE10 front. You have a leaf spring that runs through the crossmember and connects to each lower wishbone. Camber pins would shift the arms outwards and you may upset the leaf spring. Looking at the control arm, it would be hard to set it up with a threaded section without removing the leaf altogether.
Strut tops are your best bet. Stewarts old corolla pages had some sketches on it, I even started modelling them up in CAD years ago. I'll see if I can find them tonight.
ok thanks heaps philbey
cheers tom
