May 15, 200917 yr comment_344892 ok so i was leavin comp tuning and it started missing, i pulled over and checked the afm, cas, tps etc all ok, stopped missing, went to repco, bought some shit then as i left, i reversed out of the drive way, went to take off and the car died, i have no ignition power to the computer, the fuel gauge don't work, the handbrake light don't work, but the stereo works and the clock works... have checked all fuses and relays can't fault it. on the firewall, in the engine bay is the standard connector for start and ignition power, there is start signal but no ignition power to the computer but there is ignition power at the ignition switch and at the 2 connectors after it? really annoying and i will figure it out eventually but any help would be much appreciated Report
May 15, 200917 yr comment_345055 Could be fuse box lower right hand side of steering wheel or drivers kick panel that has the ignition fuse.. Report
May 15, 200917 yr Author comment_345087 Could be fuse box lower right hand side of steering wheel or drivers kick panel that has the ignition fuse.. yeh ive tested all those fuses and they are all ok... do you have the ignition wiring diagrams for ae71? Report
May 17, 200917 yr Author comment_345279 12v ignition wire to computer was shorting on the cyl head... traced that wire back to the gauge fuse in the fuse box but its wierd cos it was still lighting up the test light on both sides? anyway fixed the blown fuse and secured the wiring and re insulated it... all good now... strange tho Report
