Front Spring Question
what is the diameter of the stock KE30 front spring? I have some springs out of another car and I'd love to use them if the diameter is close enough.
Springs 15cm from out side to out side , and 15mm thick.don't no what that is in your measure ments
though .
cheers rob
really? 15mm? these springs are from a big V8 dodge and measure 15.9mm thick. the outside dimm is 13.443cm
Edited by vagen
