vagen Posted May 20, 2009 Report Share Posted May 20, 2009 what is the diameter of the stock KE30 front spring? I have some springs out of another car and I'd love to use them if the diameter is close enough. Quote Link to comment Share on other sites More sharing options...
corollaart Posted May 21, 2009 Report Share Posted May 21, 2009 Springs 15cm from out side to out side , and 15mm thick.don't no what that is in your measure ments though . cheers rob Quote Link to comment Share on other sites More sharing options...
vagen Posted May 21, 2009 Author Report Share Posted May 21, 2009 (edited) really? 15mm? these springs are from a big V8 dodge and measure 15.9mm thick. the outside dimm is 13.443cm Edited May 21, 2009 by vagen Quote Link to comment Share on other sites More sharing options...
philbey Posted May 21, 2009 Report Share Posted May 21, 2009 the reason they can run such thicker springs is because they have a larger OD. Spring rates are a relationship between 3 parameters: wire diameter, spring diameter and the number of coils. Quote Link to comment Share on other sites More sharing options...
