June 10, 200917 yr comment_351296 Hey guys I'm a car noob with a rad rolla......but theres just somethin wrong with it, its a blacktop 20 valve in an ae92.... i got it a full servive after i bought it, but its running at about half its power and is using shit loads of fuel. and its not the airlfow meter. anyhelp would be awsome cheers Report
June 11, 200917 yr comment_351372 well it wouldnt be the airflow meter because the blacktop uses MAP sensor. check fuel pressure regulator, and that it is connected to vacuum. Also check injectors, and injector seals MAP sensor might also be disconnected from correct vacuum line. Report
